Running Windows XP, Passport listed on My Computer, WD SmartWare not listed in Add/Remove, Unable to access WD SmartWare Control Center, Help.
I have been looking last 2 days on the forums for some similar case but couldn’t find anything similar. The external drive light is blinking in standby mode. It is connected through a USB 2.0 port.
Thank you for the link. It loaded the quick view monitor and icon on tool bar. Then it took some time to load the WD Control Center. I have set some of the settings but haven’t loaded anything yet. It worked. I should have asked for help sooner.
