I have recently purchased the above item and when I try to transfer MP4 files from my Mac to the device, it keeps disconnecting part way through, the re connecting. I get the error code 33?
I was also facing the same issue which you are actually mentioned in this post, after that I take a help of Hp Support Number to know the actual process to do the right thing, I know you are using Mac but , I also use Mac and this site can help Mac and window both, I think your problem will be solved properly.
