Ultra Disk Transfer Issues
I have a Sandisk Ultra Backup 16GB which works great except in one area. I took about 600 jpeg images on a recent trip and saved the images to my Laptop.
When I returned home I copied the whole file of images, about 5bg to my Ultra Backup. I then plugged it int my desktop pc and copied the file to my desktop but the photos came out distorted, just streaks of colour, no actual picture,
I did try to attach an example but it didn’t work,
any ideas?
thanks.
Bob.
May we assume the files are still on the Laptop and still work ok?
If so, what I would suggest is deleting all the files from the Backup drive, copying just a handful of files from the Laptop to the Backup and then to the desktop and see if they appear ok.  If so I would think the problem is a fluke and do more files.  If not I would suggest; a different USB drive, or a USB cable to connect the two machines, or a LAN cable.
Hi Bob, how did this work out for you? i was also thinking that the transfer was interrupted and perhaps copying those files again would fix he issue. <img src=“https://imagicon.info/cat/5-43/16x16_smiley-happy.gif”/>
Why are your emoticons usually a broken link?   If you don’t know how to insert them correctly just use the ones the forum supplies.   :smiley:
