U3 Cruzer CD partition does not appear on a specific WIN7 machine
I’m using my (quite old) 4.0 GB U3 Cruzer on several WIN machines and today, with no obvious reason, the CD partition disappeared on a specific WIN7-32 machine.
there is no pop-up window and the CD-drive is missing from the ‘my computer’ explore screen as well.
The CD partition is visible (and functioning) on all other machines (including WIN XP and WIN7-64).
Restarting the specific machine did not solve the problem.
What should I try?
I can provide screenshots if needed.
Thanks,
shai
I would suspect either a security app limiting the adding of drivers for new devices or an oxidized/dirty USB socket.
Maybe something in this KB article might help.  http://kb.sandisk.com/app/answers/detail/a_id/10/kw/cruzer%20not%20detected
Thanks Ed.
The mass-storage partition is functioning normally, so I believe there is no ‘mechanical’ limitation. I will read the article now.
Shai
