Trouble playing songs
When I select an album, the song titles on that album quickly stream by on the screen (over and over and over), but nothing plays. Any ideas on what the problem might be?
Thanks
What file type are they?  Do other files play OK?
They are files ripped from a disc in Windows Media lossless format. Simpler files do play, but I got through disc 1 of these lossless songs yesterday. I erased all the songs and tried again with no luck.
Does the Clip support Windows Media Lossless files?  Regular wma files yes, but lossless?
“Does the Clip support Windows Media Lossless files?  Regular wma files yes, but lossless?”
They played yesterday, so I didn’t bother checking.
After a bit of research, the answer looks to be no.
FLAC is the only supported lossless codec.  The Clip will roll through your files, trying to find one to play.  Retransfer them in FLAC format if you are looking for lossless.  Remember, the files will be much larger in this format than OGG, WMA, or MP3.
µsansa
