What is my Sansa player trying to say me when it repeatedley get’s stuck in loading next song, is my theory…well it can work to load next a couple of times in row after you start it, cause i think i remember me busting the display with letting the song stands at 0.0.0 in a frozen state, where no buttons works, exept resett offcorse, but moore often when it silence it has simply turned off, i have evidence of thath cause i use my player at night, its enough to slumber for 33 minutes and i allways wake up and noticed thath the player is off, offcorse still fully charged, and i can simply turn it on again and it either continues in the middle of obviosly previous track or it just restart the bad shuffling playlist to really ■■■■ me off :)
No! i accually dont have any sleep ore power saving settings “ON” in it, thath im positive on!
Now i have trying both external & internal resett and then re-syncronised the playlists in mediaplayer from zero again, but problem returns even thou
hm…could it perhaps be thath it must turn of itself if it confronts a corrupted track in the playlist…is my thauth? deleted perhaps
I have v 01.01.05, have pretty previous debricked my player, and it worked good after thath to start with…but last month the player have fallen into old pattern, i doubt it will help if i go trou the hell to try re-locate STMP3600
all im convinced on is really thath the complication appears when it shall load next song, never in the middle of one
Message Edited by Kloppstock on 05-27-2008 03:09 AM
