Could really use some help since nothing I’ve tried today has worked! I can’t figure out how to create a playlist from songs in WM11 and create a playlist…Most of the songs to be included in the new playlist are already on the Clip under the overall Music folder. Every time I try to sync the playlist in WM11, it creates a separate folder for each song and takes up more space on the Clip. How can I just create a simple playlist? What mode should I be in?
