I have an mp3 on CD format audio Bible I’m trying to load onto my Clip+. Loads fine into Windows Media Explorer and Windos Explorer on my Win7 but after loading it onto my Clip+ the tracks load out of order. Should read Genesis 1, 2, 3…20, 21, 22, 23 etc. Instead tracks read Genesis 1, 10, 11… Genesis 2, 20, 21…etc. I can’t believe I would have to change tags on every track ( at least, I hope not). Any ideas on whats wrong? Thanks in advance. JC
Interesting that your initials are “JC” and you’re loading the Bible.
My suggestion to you would be the free program mp3tag
…it has a wonderful little feature called the auto-numbering wizard…this will re-number all of the tracks at once. Works especially well if the single digits are set up with leading zeros…01, 02, instead of 1,2.
Leading zeros for numbers 1-9 should fix matters (01, 02, 03, etc.).
Thanks for the mp3tag, I’m gonna give that a try.
Yeah, and the real JC has already stood up, I can only aspire to be like Him, though I fall way short. Thanks again. JC
