Everytime i set my time, date and wallpaper it resets itself back to the old settings
has anyone else had this problem and solved it.
Are you sure you are pressing ‘Select’ (center button) when setting these options, and not just hitting the << button when the setting you want is on the screen?
yes i’m doing it right but when i turn it off and turn it back on it resets itself
i think it’s resetting itself back to factory settings
Something’s not right then. You can call Tech Support if you want (better than e-mail), but I think you’ll probably end up taking or sending it back for another one. ![]()
