Hi
The wd thunderbolt duo can easily be opened to change hard drives, I am aware only caviar green should be used unless you want to void your warranty
But can an ssd drive be inserted and used in it?
Thanks
Hi
Thanks
NO, ssd are different type of drive. You should use the drive that is designed and proven to work on the enclosure to eliminate future problems.
Unfortunately that’s not going to work, you need to use green drives only.
