Does any one know if the stock drives can be replaced with WD Velociraptor drives (1tb) to increase I/O speed?
Hi, you can only use WD Greens. Check the link below.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705071.pdf#page=26
ok it says if you don’t use green drives the warranty is void. I can’t find anything saying “only Compatible” with green drives.
