Things To Do To Your Clip When It's Dead
My little Sansa Clip died silently two days ago… ‘silently’ is a good word, the broken thing was the ‘volume up’ key.
Furthermore, I lost all player’s documents somewhere (warranty included :wink: )
So, what could I do? I dissassembled my player :>
In fact, ‘broken’ part wasn’t broken… It wasn’t soldered.
microswitch after soldering
Shame…
My solderig gun comes handy again.
Much better, isn’t it? :wink:
Anyway, I lost the warranty definitely but now I’ve got a working player (with all the case scratched like hell)
Message Edited by steev on 07-24-2008 10:39 PM
Well, you could cover it up with a nice silicone skin, but there’s not much you can do if the screen is scratched.  I’d say it just adds more character. :wink:
Brad
How did you open the case? Inquiring minds want to know!(May come in handy some day)
With a knife :slight_smile:
The smallest one from set like this one.
(some warnings : the blade is very gentle and you can easily break it and/or hurt yourself…  my knife lost its tip during this ‘operation’)
Start from left side (small area between usb and power switch) then go down.
And, well, ‘use the force’ ;)
Thanks, Steev!!
I had exactly the same problem. I took it apart and found exactly the same cause. Thank you !!!
