So I just got my fuze a week and a half ago and now out ot nowhere a white dot (or something) is inside my screen. First I thought it was on top and tried to wipe it off but it didn’t come off.
What could I do?
What could I do?
It might be a “dead” pixel. It happens sometimes with LCD screens. If that’s what it is, there’s really no way to fix it.
Have some nail polish?
Hahaha sry geek humer… Well if its speck stuck between glass cover and LCD, then stand it up and TAP TAP TAP! If its bad spot on LCD for real then BUYERS CHOICE!! If ya bought online then hmm toughie… but local place then RETURN RETURN RETURN!
Or ya can call it a beauty spot and put it on ebay as one of a kind item!
Ok I solved my own problem. It was dust or dirt inside the cover. I had to take it apart and remove it. But thanks anyway.
