I am in the process of registering this thing however Sandisk asks for a product code, where can i find it?
Thanks!
Thanks!
Thanks! Wrote down the numbers from the back of the Clip.
Just a quick question. What are the benefits of having the product registered?
Same as it is for any product . . .warranty.
And faster service should you need to avail yourself of it.
Registering your device also adds a convenient way to contact SanDisk, since you can send messages via your account.
To contact SanDisk regarding any warranty issues, the simplest method is still to give them a call at 1-866-SanDisk, as they are set up to help you fastest using this method.
Bob :smileyvery-happy:
It is actually under the events tab on properties
