The Info how much free MB on SD not correct…
I have 10215 firmware…
and SD from SANDISK…
MSC
on PC it shows correctly…I have SANSA CLIP and Removeable H: …
on H I put all folders on root directory.
MSC
If you don’t specify the discrepancies you see, it’s kinda hard for anyone to make suggestions or help.
I use 8Gb SD and about 5Mb used the rest free.
So in the info it say my SD IS free 7351MB aomthing like that…other data:
but On the PC - its OK… XP SP3 media player 11
ON internal memmory its OK…and also on PC
MSC mode - my PC with XP dont recognize MTP correctly.
after the last time I transfered songs to the Clip+ its changed to the correct value.
