The application has encountered an unexpected error and is now exiting
Few days ago I tried to copy documents from my external drive to the system I’m using but unfortunately I discover that the system just reboot automatically, the worst part of the game is that whenever I try to plug the external drive to any system  around me it will hang the system and display the message “The application has encountered an unexpected error and is now exiting”. I even try to use quick format application to format the external drive but it prove abortive,  the system will display the same message, it got to the stage that I even diasble my USB port drive, yet there is no luck,  “The application has encountered an unexpected error and is now exiting” message. I un-installed and re-installed the WD Smatware and updated the firmware…no luck. The drive  does not works on other PC’s and Macs running Windows,
My Operating system is Windows Xp and I even used Window Vista but no luck
P/N: WDBAAA3200ABK-00
S/N: [edited]
R/N: C1B
Mate, go ahead and replace that unit…
