Thank you Sansa for making a great priced, great product
@jfencl wrote:
It’s time to get used to the “When the battery dies, throw away the whole thing” paradigm.  Apple seems to love this as well.
Nope…sorry…I will never get used to throwing away a device…just because it’s not the latest or greatest…or that parts or no longer being manufactered.
I know it’s a fact of life, but it doesn’t mean that I have to embrace the practice.
I completely agree.
Why would you have 2 Sansa Fuze’s? I have a Sansa E280 and a Sansa Fuze. My E280 is my “gardening” box, for digging in the yard, or taking for a long walk (and potentially dropping). Since I have the Fuze, I can now beat the ■■■■ out of the E280. The Fuze, on the other hand, puts me to sleep and sits where I can readily access it if I want to listen to Gardening with Ciscoe onm the radio or whatever.
In addition, if you have two players, you have two batteries, so if one of your player’s battery is dead, you have the other.
But on the other hand, if you want to use the iFeast, you definitely need an iPod!
(From The Onion store)
Message Edited by MyDD on 12-16-2008 01:15 PM
The Onion rules.
The m200 series doesn’t have a card slot though. The sound quality on the m200 series is also much lower than the Fuze.
“If you design a player around a AAA battery it will be much thicker.”
I have a player that uses a AAA battery. It is only around 50% thicker than the Fuze, but is smaller in the other two dimensions. It has only onr gig of storage though. I don’t mind a larger player, as long as it comfortably fits in a typical shirt pocket.
“If you can grab a few spare batteries for your trip,  why not grab a DC charger with a USB port and connect up your cable to that?  No need for the computer.”
That means carrying the device, plus 4 AA batteries. That is heavy and bulky. I also don’t like the idea of charging a battery from alkaline batteries. I don’t even know how well that would work. If a Fuze battery is down to zero, how much play time could one get from 4 AA alkaline batteries? I guess there is no way to run the player directly from alkaline batteries without recharging the internal battery? Carrying a small player and 2 spare AAA batteries is still quite easy. Players built around a AA battery and especially those built around a AAA battery are typically quite energy efficient. The screen on the Fuze probably consumes plenty of power. I guess the screen on the Clip uses much less energy than the screen on the Fuze. Perhaps a screen like that
would be good for a AA or AAA battery based player?
"Disposable batteries are bad for the environment. "
One can use rechargeable AA or AAA batteries. I do that for my digital camera which uses 4 AA batteries at a time. My old mp3 player gets around 18 hours of play on a single AAA alkaline, so I use alkaline batteries with it.
“LiPolymer batteries used in the newer Sansa Product last for hundreds and hundreds of cycles,  just think how many batteries would end up in landfills.”
Nimh rechargeable AA and AAA batteries also last for many cycles. The difference is that they are very inexpensive, easy to replace, and up to 4 at a time can be charged in an inexpensive wall charger. Ever since throwing away an electric toothbrush many years ago since its battery couldn’t hold an adequate charge, I have had a great dislike for items that have a built in rechargeable battery.
“Think Green”
How green is it to throw away a player just because its battery no longer holds an adequate charge?
I want to use a AA or AAA battery not just to avoid this, but to also avoid running out of power, and to be able to carry spare batteries for my player, and not have to remember to charge the player when the battery is low. If I use nimh rechargeable batteries, I could charge up to 4 at a time. Some chargers take only 15 minutes to do this, while many others take around an hour.
Message Edited by JK98 on 12-16-2008 05:31 PM
Theres a simple AC adapter that connects to the Wall and has a USB output connector.  You plug your Sansa Cable in to that and connect it to your player.  You dont need to bring any batteries with you.
Your electric toothbrush used NiCad batteries most likely and yes they wear out after not many cycles.
The whole point here is LiPolymer batteries dont have the same endurance problems of the past.
 Some people want a AAA based player design. The Fuze and Clip are not it.  They are designed to be recharged, and will last a long time.
Message Edited by sansafix on 12-16-2008 03:27 PM
I think the price point of the Fuse is okay for a non-replaceable built-in battery.  After a few year, I will be looking at a cheaper, more flash, thinner, and lighter player anyway.  I know it is bad for the environment, but we are just human.  :smiley:
@jk98 wrote:
I don’t know how the Slotmusic player navigates.
By folder\filename, alphabetically.  Wraps back to the first song after the last one.  Naming files “01-…”, “02-…” lets you set the order you want.
@shlurpee wrote:
@dpvdpv wrote:
I know a lot of people with ipods that would struggle with a Sansa.
it took me a couple of hours to figure my Fuze out and I had to download MM and figure out how to get podcasts, set-up my audiobooks, read through the manual, etc., etc.
ipod/itunes is one-stop and pretty much ■■■■■-proof.
I LOVE my Fuze, now.
my to do list:
  1. start converting videos
  2. figure out how to get ipod video podcasts converted
Sansa is niche, why bother with all this when you can go ipod and not worry about any of this?
I’ve had my Sansa since Saturday and there is no point in ever going back to ipod/zune.
I agree.  I was an Ipod user, and still have my old 20 gig ipod.  I really miss the seemless software from itunes to ipod…it truley is a no brainer.  IMO, that is the ONLY thing Ipod has over most other players.  If someone could figure out how to make an MP3 player software as nice and compatible as Itunes is to Ipods…that would truly be an ipod killer.  MM is nice but I feel like I am writing software code just to get my Fuze to sync with podcasts, and lets not even talk about WM11, windows explorer is better than WM11.  So, yeah, I miss Itunes, but I like my fuze better than I like my ipod.
I completely DISAGREE I HATE ITUNES!!! IT IS THE MUSIC DEVIL EMBODIED… The reason I love sansa with all the extra work can be described in one File extention… mp3… I hate the idea of proprietary music files from the itunes store, the same for my movies and TV shows… This is why I bought my first sansa. I was selling electronics at the time and spent alot of time researching the products on the market. I sent my customers to the Zune and my friends to Sansa (At the time the e200 or connect). It would have been easier and more conveniant to buy the iPod but I like my music my way. And now its too late to change… I have 10,000 songs, that would talke Itunes forever to deal with.
If there are two evils in this world, they are ITunes and WMP.  Both are clunky, ill-conceived pieces of software and I would not shed a tear if both would go away forever.
I came to my Fuze from another popular brand of Windows-based players, so my learning curve with the fuze was minimal.  However, if I have a small complaint about the product and the way it is presented to the consumer, it is the documentation that is supplied with the unit.
Sure, for many, the documentation is ample as we are familiar with audio players and their usage…However…there is a growing number of older or not computer savvy people that are just getting into portable audio market; and I know their learning curve is significant.  No matter how great a product is, if it isn’t straight-forward and easy to use, many will shy away.  Take for example my elderly mother.  She would love to have a personal audio player; but I’m afraid she would have significant difficulties with just the basic usage of the device, as it is now implimented.
Don’t get me wrong, I love my fuze, and for us tech savvy people, it is fine just the way it is…But…for future growith with the product (not just the Fuze model) Sandisk needs to improve the documentation and make the device as user friendly as possible.
Sorry for the rant…
This is so hilarious !!! :slight_smile: :slight_smile: :slight_smile:
MyDD wrote: -----------------------------------------------------------------------------------------------------------------------------------------
But… It still pains me to throw out a device just needs a battery…:cry:
My five year old Rio Karma has been used regularly all the time I’ve owned it and only recently did I have to change the battery. Even then, although it wasn’t holding as much charge as it should, it was still useable. That battery wasn’t meant to be user replacable either, but I still managed. :wink:
"Don’t get me wrong, I love my fuze, and for us tech savvy people, it is fine just the way it is…But…for future growith with the product (not just the Fuze model) Sandisk needs to improve the documentation and make the device as user friendly as possible. "
I guess that is the idea behind the Slotmusic player. Some want an mp3 player that is as easy to operate as a portable CD player. Notice that a portable CD player does have a display though, and uses one or 2 AA batteries. Many who are not comfortable using computers want a player that can be used without having to use a pc on a regular basis for charging the player. Some cringe at the thought of having to connect anything to a pc. I still see some people carrying around a portable CD player. A few years ago I thought this was due to the high cost of mp3 players, but now I think it is due to the fact that most mp3 players have a built in battery, and are still not so easy to use since they navigate based on tags. Digital cameras can now be used without a pc, and there are easy to use kiosks where one can have prints made from images on flash memory cards. I guess the  Slotmusic concept is to make mp3 players able to function without access to a pc. Now that we have the tiny micro SDHC card format, will this be taken a step further to an even smaller format, perhaps named submicro? Micro SDHC cards are already so easy to lose due to their small size, and swapping several cards while walking around doesn’t seem so practical. There is still no easy way to consolidate a few micro SDHC cards into one without using a pc. So there are still some impediments in setting up a practical system for selling mp3 music and having someone use it without accessing a pc.
My mother is pretty computer literate, but she still feels the way she would have to get music onto a fuze a bit beyond her comfort zone.  Slotmusic may be fine for some, but it wouldn’t be a viable alternative to her, as she mainly wants an mp3 player to transfer her 200 or so CDs to a portable device.
I really hate to do it, but I am going to get her another brand of player that uses their own, simple to use software for adding and managing content.  It’s not as good as a fuze, but the interface is simple enough for my mother to use.
That was my point all along.  Sandisk has great products, and are fine just as they are for people that are tech savvy; but could to be made more user friendly for those that aren’t.  People shouldn’t be forced into an “either”/“or” situation.  I know portable audio devices can be made more easy to use…Not knocking Sandisk; just making a point to where their development team may wish to look for future improvements.
Although I think it would be great for the Fuze to support folder browsing so that I can just chuck on some short-life randomly obtained music without having to worry about tags, if what your mother wants is something that will handle her own CDs, then surely it is easy enough to rip and tag them correctly, with something that will look up via FreeDB or similar? I find most of my CDs are one-click with the correct software.
Message Edited by pelago on 12-18-2008 10:59 PM
I have found many an error in the tags on CD’s and through on-line databases however. You still need to know how to correct/edit the information with a program like MP3Tag, which makes it fairly painless. Although my mother, God rest her soul, would’ve probably have trouble with it too. THAT’S what her bright & caring son is for! :wink:
That’s my point.  A person shouldn’t have to use a seperate ID tagger program to get satisfactory results … that is, unless they want to.  Consumers should be given a choice.  If you want to use WMP, MP3Tag, or other programs that is fine; but many consumers may feel intimidated by all of these programs.
I still believe that there should be some sort of Sandisk simplified software that is bundled with all players that will allow for painless creation of MP3’s (or flac or ogg) right out of the box.
While I still think that my 8 gb fuze is the best player I have ever had, my previous personal audio device had the right idea.  Bundled with the player was a very simple software program that allowed for easy creation of playlists, mp3’s and other things, right out of the box.  It was designed for the player included, and it worked well.  You could do everything one could imagine, with audio files with one simple program and interface.  I don’t miss my previous player much, but I did like that software.
I’m not going to base my buying decision, next time around if Sandisk creates such a bundled software; I just think that is one of the few things that could make a good product great.
To be honest, I don’t have a huge problem with either.  The difference is that you must use iTunes if you have an iPod. You can go your whole life, however, without having to use WMP.  I do use WMP to sync to my Fuze and have never had a problem with it.
Out of interest, what was the player/software?
Out of respect for Sandisk, this is not the place for that information…Sorry.
Message Edited by fuze_owner-GB on 12-18-2008 03:59 PM
