Test card for error
Is there a special “Test Card” utility for Sandisk ?
Looking for error, find speed
I have a new 132 GB I can’t save files to.SD kort alene
Hi @stonefox,
In order to check speed of your memory card we recommend you to please use below software to make a general assessment of your testing.
To download the software, please refer to below link:
Windows: CrystalDiskMark
Mac: BlackMagic utility
• Run the file and Install the software by following the installation wizard.
• Once the software is installed, please locate the “CrystalDiskMark Application” icon on the desktop
• Double click the icon and then select the SanDisk memory card in the Device box.
• Run the speed check read & write speed.
• Once this process will complete, share screenshot of test results with us on support@sandisk.com
Hope it helps!!
