system info question
when an sd card is in the player is the extra capacity supposed to be seen in system info? mine only shows the player capacity with or without the card plugged in.
thx,
chuck
It should show the capacity of the SD card under System info.
Jamieson,
Yes in system info i see a capacity but is it only the player or the player capacity plus the sd card capacity? that was my question.
It will show the capacity of the internal memory and the SD card seperately.
Keep scrolling down under “Info,” and you’ll see the SD card information at the bottom.
thx hulksmashnow,
i found it in system info!
@chuck_w wrote:
thx hulksmashnow,
No problem.  Glad to be of some help.
