Syncronizing
I’m not sure if this makes any sense. When I sync music to my device, everything seems fine but on the side of the screen that shows the songs on my device, it doesn’t show the songs I just syncronized. The only ways I find out if they are there is to disconnect the device then check. Also is there a way to sort the songs on my device when they are shown on the computer screen(I know they are automatically on the device). Any suggesations?. Thanks.
leonard h
what are you using? in wmp 11, there is a sync tab.
