When I sync to my sansa clip zip with it syncs songs that are already on the device. I think its because the file modification date doesn’t update. The modification date on a file on my hard drive would be 13/08/2012 but when you put the track on to the clip its 13/03/2005. So the program I sync with thinks the files need to be updated. Is there a solution to this.
Yes. Don’t sync.
its not a program problem its a problem with the mp3 player
Yeah, the date and time is correct. Even if I use windows explorer to copy the files to the clip the mod date reverts to an old date.
Stop trying to sync. Sync=sink! Don’t fall into the abyss. Just copy and paste folders of files to the player in MSC mode. It is so simple and without drawbacks.
Why doesn’t synch work? Often synch works unexpectedly or doesn’t work at all. Sometimes too much automation is very counterproductive. There are so many posts of people mysteriously losing songs, or getting plenty of unwanted junk put on their player. Imo the whole concept of synching is flawed, and it should be avoided.
