Hello, I want to sync ratings which are very important to me since I have a lot of music. I can get ratings onto the Fuze when I sync the files but I want to sync new ratings from device, to the computer (and vice versa if they are unrated on Fuze but rated on laptop.)
Its in MTP mode as I know that it needs to be to sync ratings.
What is your question/problem?
You have the Fuze in MTP mode. Open up Windows Media Player 11, plug the Fuze to the computer. WMP11 should recognize that a device is plugged in.
You should be given the option to sync you Library with the Fuze, and your ratings should transfer over.
What isn’t working for you?
I want to sync BACK to PC but it doesn’t seem to let me. For example when I plug my iPod into iTunes, it syncs BOTH ways. This is only syncing ONE way, PC to Fuze.
BUMP!
WMP11 still won’t let me sync back to PC from Fuze…
