What you are trying to do is not recommended since it will likely degrade the RAID array. “Mirror” does not work by first copying the data into drive A and then copying it again into drive B, but rather copying the data into drive A and B _ at once _, and mirroring back from either A to B or B to A in case of a drive failure requires for drive C to be empty.
I’d recommend a completely separate hard drive working in tandem with your My Book Duo.
You can connect other USB devices to the USB hub ports in the unit regardless of RAID configuration as they will mount independently from the unit (It will not “fuse” all available storage). However, you will need to either manually copy/paste the files from the WD My Book Duo to the other USB drive or use a third party automatic backup/synchronization utility to handle the process since WD SmartWare is currently a Windows-only application.
