I need to know, with certainty, if the files of Incredimail Software are supported in “WD - My Passport Elite” unit. Thankful.
I’m not sure if I understand your question, but a drive is simply for storing data on it. File types shouldn’t be an issue. Remember, inside that passport is an internal hard drive that should work in any laptop, which means it should be capable of having any file written to it.
As our good friend Wayne sayd, this is simply a drive and it can hold any kind of information, the format of the file/s should not matter, unless you would like to make an automatic backup of these files, in that case you would need to check what backup software you are using and if this backup software supports the file-types that you would like to backup.
