Hey there,
Well after a couple of hours wrestling with the firmware update i finally got my express functioning again (it was stuck on the ‘building database’ screen) after an update failure. Everything seems to be working well now, except for one thing that wasn’t happening before the update. Now, when i am playing a song from music directory and hit submenu button, it sometimes takes 10 times before it registers and takes me into the music submenu. The button works everywhere else. It’s just when im on the current playing track info screen and hit the button, which leads me to believe it’s more of a firmware problem than a hardware problem.
Has anyone else had this problem?? or have any suggestions before i exchange this for another one or possibly something else??
Is there another firmware update coming that may fix this problem??
Thanks
Well It seems like that problem is gone for now. All buttons are working properly. A good old Format seems to have done the trick. Since then everything is working perfectly. (i had to format anyways because i had some read only folders on there that i couldn’t remove. Lesson learned.)
Message Edited by dreday on 08-26-2007 11:27 AM
