I’ve 1 TB My Book Elite and recently the disk activity on it is 100% and i can do nothing with it. The funny thing is, that no programs use it at all and I get this (just connected it):
Indexing is off, Windows SP3, all smart and self test is OK, antivir disabled, defragment 0%, no program use (i can see it from Process Monitor) also no processes use it (Process Explorer).
I’ve never used the automatic backup. It’s just a storage for changing data between work and home, and i handle everything manually with total commander.
I’m using Avira Antivir but it was turned off, and I saw nothing in Process Monitor as I mentioned in the first post. I think one of the firmware upgrades did something, and its defragmenting itself / doing some maintance thing (that is my wildest guess, coz i never run defrag on it and it’s still 0% defragmented after 1 year)
Your image doesn’t show a list of running processes. I mentioned the antivirus because I had problems with AVG in the past and seems troublesome on Windows 7 crash dump analysis. Do you use a third party Defrag program? I’ve got a My Book Pro II and had problems and I finally traced to to using JK Defrag. What about check disk is that running? What about indexing on the external it’s in properties?
