Probably a simple answer.
Just wondering how have a song stop automatically after play.
Mine will continue onto the next song and so forth.
Thanks
Thanks
It could be possible that the other songs cannot be read by the player. Try loading other songs here. ![]()
Huh? How is that going to make the player stop after playing a single song (which is what the OP is asking for)???
There are several ways to do this. The easiest is to put the song on the go list, with no other songs there, then play the go list. If you aren’t using song ratings, you could give the song a 5 star rating, then play highest rated songs. If the song is the only one you gave that album tag, then you could play that album. If the song is the only one you gave that genre tag, you could play that genre. If the song is the only one in the player by that artist, then you could play that artist.If the song is the only one in a folder, then you could use folder browsing and play that folder. There are probably a number of other ways as well. The first two suggestions, putting the song on the go list, or using song ratings, can be set up on the player itself. The other methods need to be set up in advance. Most people waste the genre tag, which can be used creatively.
