Still having problems connecting
I have scanned most threads in my pursuit for solving my problem connecting my Clip til XP. Windows will not recknonize my USB-unit, and it therefore doesn’t appear in ‘My computer’ :frowning:
Firmware version is V0101.18F. My item is brand new. I am running XP with SP2 installed. The Clip is in MSC-mode.
The Clip displays ‘Connected’.
What am I doing wrong?
Message Edited by STKO on 02-28-2008 01:00 AM
Dooo … error40 !! (error located 40 cm from the screen … i.e. me)
This time I tried to use the original cable from SanDisk … voila! Everything works.
LOL
LOL
Another USB cable wouldn’t work?  Strange.  Either the cable was damaged or … I don’t know … does the power supplied over a USB cable drop significantly depending on its length?
