Please anybody let me know what this is i cant use launch cast radio but we have two sansa connects and the other can use launch cast radio perfectly!!! SSL CONNECTION ERROR ???
IF you have 2 units exactly the same and you are using them exactly the same with the same wireless network,
then I would conclude you need to try to reload the firmware first.
Try the Connect Recovery Tool.
