I bought a new pc and only used it for 65 hours. now i only updated windows 11 and installed pc drivers and installed some programs and used it for light browsing that’s all no gaming or heavy programs so is this read and write usage normal or is it SSD excessive writing problem or a problem with ssd should i replace it or is it issue with windows 11. by the way most of the time there are no ssd usage write/read processes in task manager and process monitor in windows 11 also i have disabled hibernation and moved all temp folders for browsers and download managers to hdd not ssd to minimize ssd usage ?
the following are screenshots of crystal disk info & sandisk dashboard
see power on hours and total read/write usage is this ratio okey ?
(Get Support for Your SSDs and Flash Products | Sandisk)
(Contact Support | Sandisk)
