Hi Lorenzo, Eismann,
Thanks for the confirmation that the tool doesn’t crash.
Performance monitor is not always available on all Windows platforms.
Can you confirm the following for me:
Run “PerfMon” from any command line window, or from “computer management” console, open the “performance” tab.
Under “Monitor Tools”, click “Performance Monitor” tab
Click on the green + button (Add Counters)
Check if the “PhysicalDisk” option exist
Thanks for your help
Phisical disk option exist
Thanks Lorenzo,
2 options:
open the registry: run “_ RegEdit _”
navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PerfDisk\Performance
do you see a key name: " Disable Performance Counters "
it should be set to 0
if no key, just do nothing
rebuild the counters pointers:
Open a command line in Admin mode
go to " C:\Windows\system32" on a 32bit system or “C:\Windows\SysWOW64” for a 64bit system
run the following command: " lodctr /r"
Hi georgealon,
I also have the Physical Disk option:
The “Disable Performance Counters” key doesn’t exist in my registry, “lodctr /r” was executed successfully, but the performance chart still doesn’t work.
Hi Eismann,
I have 2 questions for you:
can you plot all the counters under PhysicalDisk in PerfMon tool?
Can you generate a report using Dashboard (Help tab->Generate Report) and send me the files created.
Thanks, we’ll try to reproduce your issue with the chart.
Hi georgealon,
https://www.dropbox.com/sh/kjmdx7xbc7h3hip/AABHOR3zzvef4-UxCtRa1Plia
There you have one picture and your two report files. I guess it’s plotting everything, at least it doesn’t give me any errors.
For me, same Eismann situation, not key on regedit founded, and cmd command not resolve the problem, this is my ssd dashboard file:
https://www.mediafire.com/?t9erhszjw3pc4gg
Hi Lorenzo, Your link doesn’t work.
What is your system info? Windows version? service pack?
The link seems work at me,
system info:
Windows 7 home premium 64 bit service pack 1
We have found an issue with the performance chart under foreign languages version of Windows.
We should have a fix on the next revision.
Thanks
Performance chart is ok with version 1.0.3, thank you for support
