Spoken Word is what?
Yesterday I received a brand new refurbished M230 with 2.2.5A firmware. No stopwatch like the literature says it should have, but it seems to be working fine so far.
I’m using Itunes with an add-on called “Itunes Agent” to synch Podcasts to it with no trouble as long as I keep it in MSC.
But when I look at the information, there is a file storage section call “Spoken Word.”  Is that for audible files?
Yes, it is for the Audible files. This is covered in the User’s Guide at:
http://www.sandisk.com/Retail/Default.aspx?CatID=1304
You can either download or view the manual online.
