Sound
The sound on one side goes on & off depending on clip movement ( I used 2 different headsets).
Moving the headset cable a little does the same thing.
Thanks for any suggestions.
GG
Bad solder point.  Return it for a new player.
Thanks for the reply. I’ve had the clip for 9 months & use it about 3 hours/day. It just started acting up.
GG
It’s most likely the phono socket. I have the same problem with a Sony walkman, which I can’t fix. Internally the socket is a plastic molded block soldered to a circuit board. Not sure what the clip is like inside but I doubt you can fix easily. The phono jack is a potential problem on any device. I leave mine inserted most of the time
