Currently I have the SD Card set up to have a playlists and music in seperate folders off the root directory. I have the internal memory set up to have a folder for all the music and playlists with no sub-directories. In both cases some of the playlists do not list all the songs that should be there.
If I remove the SD Card and put it in the Clip+ everything is displaying without problems.
I have had the playlists and music in the same directory on the SD Card and the same problem presents itself. On the Clip+ I have the same file structure and there are no problems at all.
The M3U playlist displays like this
…\Music\Depeche Mode\Delta Machine\204 All That’s Mine.mp3
And equally if the music and playlists are in the same folder it reads:
I have experimented with path lengths too by not having sub-directories such as :
…\Music\204 All That’s Mine.mp3
I am at a loss and I have tried just about everything I can think of even having everything in the root folder.
