My sister and I just received Fuzes for Xmas. We ripped and synced albums and songs from our cds via computer. Some copied fine, others just cylce through the song titles but will not play. We, downloaded new software, updated windows media player, reverted to factory settings, did the 10-second refresh, etc. but still have the problem. My dad has a Sandisk but does not have any problems. We also have a Zune w/o any problems.
Several people told me that they thought that they had rushed it to market w/o resolving some known kinks, or that the new Fuzes were ■■■■, but I’m not ready to give up on them yet: at least for the moment.
Thanks
Have you tried deleting these songs, and then Re-syncing the files? Try that first. If that does not work try rebuilding your root database, (one of the Gurus Nutron Bob Posted it in another thread) You do that as follows
It’s possible that you might have a messed up music database file as well.
Connect in MSC mode, and look for the mtable.sys file in the root directory.
Here’s the fun part, simply delete the file, and unplug. The Fuze will generate a new one from scratch, hopefully without duplicates.
Are you ripping these CD’s to .mp3 or .wma format?
If you are ripping in .wma format, the default WMP setting may still be on that applies ‘Copy Protection’ (DRM encryption). That could be why they won’t play on the device. Or it could be that you are using WMA Lossless, a format that is not supported (won’t play) on the device.
Try ripping one or two of the problem tracks as .mp3 to your computer. Delete the same tracks from your player, so there won’t be 2 copies on it to confuse matters any worse. Now instead of ‘syncing’ them to your player via WMP, just drag & drop them from your computer (in Windows Explorer or My Computer) to your player’s MUSIC folder. You can do it in MTP mode on your player, but I prefer MSC. It’s cleaner, easier, and less complicated (for both you & the computer). The mode can be switched in SETTINGS > SUSTEM SETTINGS > USB MODE. I’d advise against using the Auto-Defect setting at all.
Do they play now?
It’s also possible incorrect or corrupted ID3 tag info could be causing the problem(s).
And btw, this statement:
[Several people told me that they thought that they had rushed it to market w/o resolving some known kinks, or that the new Fuzes were ■■■■]
is just not true and those who are perpetrating it are just as they describe the Fuze . . .full of it.
Try ripping one or two of the problem tracks as .mp3 to your computer. Delete the same tracks from your player, so there won’t be 2 copies on it to confuse matters any worse. Now instead of ‘syncing’ them to your player via WMP, just drag & drop them from your computer (in Windows Explorer or My Computer) to your player’s MUSIC folder. You can do it in MTP mode on your player, but I prefer MSC. It’s cleaner, easier, and less complicated (for both you & the computer). The mode can be switched in SETTINGS > SYSTEM SETTINGS > USB MODE. I’d advise against using the Auto-Defect setting at all.
Do they play now?
is just not true and those who are perpetrating it don’t know the facts and are just as they describe the Fuze . . .full of it.
