Song Playback Order
I’m having trouble putting my songs in a specific order on my sansa.  I’ve tried numbering the tracks and adding alphabetic sequence to the track tittles.
You can either create a playlist, or you can use Folders view.
Modifying the filenames will only affect the playing order when using the player in folder mode. To modify the playing order when using album mode, you should assign a 2 digit(with a leading zero if needed) value to the track number tag for each song in the album.
Thanks for the help
