OK, so this device clearly isn’t really compatible with Macs, since everything I copy over from my Mac podcast files refuses to play. And it’s not very compatible with Windows, since when I try to drag and drop files (or even copy and paste) from my Vista music folder, I consistently get an error message saying the device has either been disconnected or is not responding. Note these are all mp3 files.
A number of people reported needing to format their new Clip+. I think some of the sample songs may be corrupted. I hope you formatted the player using the player’s menu, as the player will function best that way. If not, you could format it again using the player’s menu.
I did use the device’s internal formatting feature; thanks! That seems to have been an effective fix.
The incompatibility between the Mac OSX and this device is unfortunate, since I have relied on the Mac to do things like sync my music to a listening device. But at least now I can transfer files to it from Vista.
