hi all,
I’ve solved most of my problems with SMC by installing the codecs as indicated on this thread:
I don’t even need to use another converter - it works directly with SMC
the only thing is that with some videos I’m trying right now, when I do several files at a time, the first file works perfectly but the other ones are cut after 30mins, and the image is completley hazy (as if I could see diifferent parts of the image in different places of the screen). So I have to do onea at a time, and cannot launch a batch of files when I go to sleep.
Any ideas?
thanks!
