How Can I go about restoring these files. Do I have to tell SMARTWARE to re-import them or something. It looks like it has lost track of all the backups it’s done!
I am inclined to believe the files were not copied with WD SmartWare as the posted pictures do not reflect the single backup structure used by WD SmartWare.
This backup structure is:
Disk drive> wd smartware.swstor> Names of PC’s backed up> Volumes> Users/Documents and Settings> User Profiles> Files.
It does not keep individual backup folders per date.
It would be best to confirm the exact application that was used to create the backups as WD SmartWare will be unable to restore backups from 3rd party applications.
You were right. They weren’t using the SmartWare software included in with the drive. They were actually using Windows Backup. I had checked if they had been using Windows backup just encase but the Virus had wiped out all info that the machine had been backing up.
