Hi. the other day for some stupid reason I decided to update my firmware. I updated to 01.02.24A on my version 1 E260. Ever since the reponse to button presses has been very slow and sometimes there’s static when I listen. It goes away if I adjust the volume slightly but I shouldn’t have to do that. Is there any way I can reload the old firmware? I never had any issues with it.
thanks in advance for the help!
Sure, you can re-install the previous version 01.01.18. I can’t say as I’ve ever heard anything like you’re describing after a firmware update though.
Just follow the manual installation instructions in the post.
Yes, I still have static on my device and it is still slow to respond. I’ll check to see if I can find those files on the MP3 player. Ok I checked and I dont see them in any of the obvious places. I connected it to my computer and opened it. I checked each file. Is there anywhere else I should look?
Update to my Update…didn’t even have to wait a day to see how it acted. It’s still has intermittent static. Anything else I can try? I hate to buy a new one if this can be fixed.
