Are slotmusic cards and slotradio cards interchangeable and can both be used with a fuze?
the content on slotmusic cards is drm free mp3 so they can be used anywhere with any device that supports mp3 playback. slotradio cards are a little different and use protected content that can only be played back on specific devices. Currently the only devices that support slotradio cards are the slotradio player and now with the latest firware the Fuze. to answer your question yes as long as you make sure you are using the latest firmware you can use both slotmusic and slotradio cards with the fuze.
Message Edited by drlucky on 06-03-2009 12:39 PM
Does it work in reverse? Will SlotRadio play any Micro cards, or do they have to be SlotRadio cards?
According to the SlotRadio FAQ:
4. Can the slotRadio™ player read microSDHC™ cards?
Yes, in addition to slotRadio cards, the slotRadio Player can read both microSD™ and microSDHC™ cards.
the content on slotmusic cards is drm free mp3 so they can be used anywhere with any device that supports mp3 playback and you can also copy them to dvd using softwares like clone dvd etc.
<spam removed>
Oh, you spammers are really getting sneaky. ![]()
