How do you delete the slot radio advertisement that shows up when you play all files with rockbox on the clip+?
I didnt install rockbox on my clip+. I was able to remove the ad tho by doing the manual update. There’s 2 files when you download the firmware, a “bin” and “dat” file. Just load the bin file. The dat file is the ad if I am not mistaken
