I’ve seen that the player has “power saver” and “sleep timer” which both work in different ways.
I’m coming from a Creative Zen that had a function where if even when you’re playing music after X minutes of inactivity (no buttons pressed) the player turns off. This is a settings that is always on and I have to set it only once. Instead of the fuze+ I see that the sleep timer just works as ,… a sleep timer. Meaning that
1- every time you turn the player on you have to set it
2- it turns off even if you’re using it.
Is it possibile to add this feature? Its basically a sleep timer always set that everytime you press a button restarts the countdown. It’s useful when you go to sleep with the music on.
