Skipping...
My Sansa clip that I’ve had for less than 2 months keeps randomly skipping at times. The first time it happened, I shut it off and it went away. I think it happened twice after that, but then it happened again yesterday and nothing is solving the problem. I did what the instructions advised and tried pressing my power button for 15 seconds and that didn’t help either. Help please! :/ Thanks…
You also could try reformatting it, under the Clip’s settings.  Note:  this will erase your content.
