Simple Batch File for Playlist of all Podcasts
Are you frustrated by the inability to sequentially play all the Podcast Files on your Clip Sport  (and Clip Jam) ?
Then maybe try this idea and see if you can make it work for your needs.
  1. Use Windows Notepad to create this 1-line textfile (as Podcasts.bat) inside the main Podcasts Folder.
         dir /o:n /s /b *.mp3> Podcasts.m3u
  1. Use Windows File Explorer to double-click on the Podcasts.bat file.
3, Then move the new Podcasts.m3u file into the main Playlists Folder.
  1. Use Music play mode or Card play mode to select your new Podcasts Playlist. (Folder mode does not use Playlists.)
Linitations:
   Music mode does not create “resume” points.
   Music mode does not allow slow or fast play speeds.
Please reply with comments, suggestions, etc.
