Hell i buy used in damaged disk WDP 1T.
Dis was damaged i insert in him old 120GB disk Toshioba for tests
NOP…Disk no brodkasting wifisignal
Hmm where is there problem ?
Really nobody dont knows
I bu now the same disk as oryginal WD10PSZX mayby tahat is a problem
Try and rephrase your question and be more specific, because it is a bit difficult to understand, what product/device you have, and which problem you are asking for help for…
I bought a used WD Paassport PPRO 1TB It does not broadcast the WIFI signal. I do not go anywhere with his nets. Because he did not bot and duysk made noise, I changed it to another 120GB, Still no changes, although it turns on normally
Best chances to get it working again would be to use a similar hdd brand, like e.g. WD Blue HDD to make sure, that hdd and device controller are compatible. It may also work with your Toshiba laptop disk.
A new disk has to partitioned and formatted correctly though, with a reserved, separate 4gb partition for flashing the operating system. You can find posts on how-to on YouTube and in other threads on this forum, e.g. here: Hardware factory reset
OK ! Resolved !
I put new disk and BAck to live
Good to hear
