Does it cause any damage to the player if it is not charged very often as I am thinking of buying another for a family member but He wont use it very often and it will only be charged once in a while.
Will the battery degrade in any way if not charged regular or for long periods?
Cheers all.
Floydian
It uses a rechargeable lithium ion battery like with mobile phones.This will retain at least 80% of its capacity after 400 charge/discharge cycles. A properly maintained battery is used regularly
I would suggest telling the recipient to use and charge the player at least once a month.
I just got my Garmin GPS back from warranty service. Turns out, it needed a new battery. Turns out, the tech told me, the battery stays healthier and lasts much longer if it’s discharged and charged on a fairly regular basis. I use the thing very infrequently, but I’m gonna make sure it gets cycled every couple of weeks.
