Hi there,
Is there a way to set the maximum volume level for my daughter’s SE? I want to preserver her hearing.
Thanks.
Hi there,
Thanks.
Unfortuately no. That feature is lacking compared to the newer iPods. But there is a setting where you can set the max volume from normal and high settings. It’s in the Settings > Volume Then you’ll see 2 choices.
