When I installed my new 2 TB MyBook yesterday, I received a message that no SES driver was found so not installed. The rest of the install kept rolling along smoothly, but now I’m doing some reading about how necessary it is. How do I go about initiating an action that will get this installed for me? I’m running Windows 7 Home Premium.
"Problem: Windows attempts to install a driver called the SES Driver every time I connect the drive to a computer. What is this driver, why is it required and how can I get rid of the repeated prompts to install the driver?
Cause: Your new Western Digital My Passport/My Book hard drive requires a special communications channel (SCSI) between your PC and the drive to enable certain features such as password protection, LED control, and access to the drives label if applicable.
At install, the Windows operating system detects this SCSI communications channel and attempts to install a SCSI Enclosure Services (SES) driver. This driver is only used by your hard drive and is installed by default when you first attach the drive to a computer.
However if you did not install the driver upon first install and chose not to install WD Smartware, Windows will continue to prompt you to install the driver each time you connect the drive to a computer. This will continue to occur unless the SES driver is installed.
Solution: We recommend that you install the driver by selecting the Install the software automatically option on the popup screen. Windows will automatically find the Windows SES driver online, and the prompting will disappear. This will not affect your operating system negatively in any way."
