I have a Sansa c140 since some years now, I used it mainly as an USB drive, for storing/moving files, and sometimes I’ve used it to create bootable OS images, for linux ubuntu for example, and it worked well. But then one day I was trying to create one of these bootable linux into the player, and I don’t really remember what happened, if my computer crashed or the software I was using hanged, anyway the result is that the mp3 player capacity seems to be FULL but the bootable image didn’t got created 100% so the device wont boot. So I tried to reformat it or delete some files, but the player wont work. This is whats happening:
First when I turn it on (takes like 3 minutes to finish loading the sandisk splash), it shows me the message: “No Space For DB, please delete more than 4.0MB”.
So then I set the USB settings to MSC, and I plug the cable in, in linux (ubuntu 10.04), nothing happens, I don’t get it recognized like an external disk like it use to happen. So I can’t delete or reformat from linux.
Then I went to a Windows installation, I plug the player cable and it does seem to recognize an external disk, but explorer.exe hangs when I open “My Computer” folder and it never unfreeze, I have to unplug it and relaunch explorer.exe to continue, I’ve also tried to access the device from a CMD window, it will hang also.
So I don’t know what to do now, how can I get this device reformatted so I can use it again?
ps: I never used the “Auto detect” USB mode (MTP), but I think it algo hangs in the same way.
